Passenger side fuse panel
Hi,
I have a UK (RHD) Mazda 5 and need to find the Air Conditioning fuse. The handbook says it's in the passenger side fuse panel but I can't find any fuse panel in the passenger side footwell. There's a panel above the glove box but I think this just houses the ECU (I'm guessing here - all I can see is a black box with a block connector plugged into it).
The handbook has a diagram of how to find the engine compartment fuse panel (very helpful but not the panel I'm looking for).
Any ideas where this panel is?
Cheers,
Phil
Cheers,
Phil
Found it!
Eventually I found it. It's just above the passenger door hinge but crucially you can't see it unless the passenger door is open (open the door fully and there's a black panel marked 'Fuse Panel' above the door hinge).
Unfortunately the A/C fuse is in tact which means either my 5 needs re-gassing or something's wrong with the A/C system
punkascii
08-10-2009 05:34 PM
