Rear wiper arm replacement?
I'm assuming that model to model it will be the same... at the base of the arm where it connects to the hatch... there is a plastic cover that snaps on and off. remove this and there will be a nut or a bolt (usually a nut), remove this and the arm will come right off. hope this helps...
here are some pics to go with my last post...
the base of the arm
the cover that snaps off
once again I hope this helps. are you replacing with a factory arm or something different? I would like to replace mine as well just for the ease changing a refill rather than trying to find a blade to fit. let me know.
the base of the arm
