Serious issue, nearly a fire..
Hi folks,
I have a 2007 Mazda five with 57,000 miles on it. While driving yesterday I smelt burning. I pulled over and saw smoke coming from under the hood.
The leads that connect to the alterntor are covered by a plastic looking cover. This cover was smoking like crazy and about to catch fire. I had a water bottle so cooled it off with the water.
The charging system is still working, I checked with a meter. It must be getting real hot to do this. Maybe it is overcharging to do this?
Any suggestions?
Thanks in advance. Fred
Any suggestions?
1) Take it in and get it tested.
2) Do you have any large extra draws like an extra amp? If you do you need to run 2 extra grounds. 1 from car body close to battery to negative terminal of battery. 2nd one from engine block to negative terminal of battery (you could do this as well, extra grounding is good). Check stock ground around battery at body for corrosion. Clean your battery terminal if corrosion present.
3) Take it to a garage to get it checked out. Same as #1!
No extra draws but I did have the AC running, which I rarely do. My meter is now NOT showing a charge but the charging light is going off when I start thye motor!! Strange! Suggestions? Earlier mistake...it is a 2008 model.
Anyone suggest anything. Looks like after removing the plastic underneath I can access the 2? alternator holding bolts. The thermostat went out last fall and the transmission also failed a year ago. The tranny was under warranty thankfully. Not having much luck with the Mazda, shame as I like it.
Fred
The latest... I put my hand on the wiring connection on the alternator and it was so brittle from the heat that it just snapped off. Will now need the wiring to the alternator. Any one know how long it is to a connection? As expected the battery charging light remains on now.
Fred
Fred
Fred
Don't know where it gets connected to or how long. Safe bet is to the positive side on battery if needed in a pinch, especially if wire is fairly thick.
Good Luck
It sounds like the connection was loose and overheated, my mom had a 1992 Ford Taurus 3.8L that the nut holding the positive wire onto the alternator loosened and did the exact same thing that happened to you, it overheated and melted both the plastic cover and the mounting post of the alternator itself.
Timothy Wang
05-14-2015 03:41 AM
