Shift lock and bearing issues?
Old 12-31-2008 | 09:49 PM
g099521's Avatar
Default Shift lock and bearing issues?
My shifter will not move from the park position, even with the brake on. I removed the shift-lock bypass cover and manually shift right now. I searched and could not find a common issue across Mazda models, so hoping someone has some helpful advice/experience.
The front right (passenger side) emits a humming noise at lower speeds. I think it's a wheel bearing, but am not sure. Any tips/advice to diagnose?
Funny how I just happened to go over my 36K mile limit for drivetrain warranty
Old 01-02-2009 | 11:34 AM
g099521's Avatar
Default RE: Shift lock and bearing issues?
Played around with the wires/connector going to the brake switch at the pedal. Looks like a coouple of wires were touching and may have rubbed through (enough to short). I pulled the wires away from each other and the brake lights work again and the shifter shifts.
The switch is fine, but if you have a similar issue, try to check the 2 wires first. It is NOT easy to get to it all... Upside down with almost no visibility. Had to feel my way. I did not see how to remove the lower dash panels, but I'd recommend that you do.
Bobbby
06-20-2024 07:27 AM
Synge
09-07-2013 12:06 PM
ptbpilot
02-09-2009 11:32 AM
Denis Mahony
06-07-2007 05:55 PM
cincera
03-06-2007 06:20 PM
