05 Mazda6 3.0 blown motor question..
Old 06-05-2012 | 08:41 PM
DWilson23's Avatar
Default 05 Mazda6 3.0 blown motor question..
I have a 05 Mazda6 3.0 M/T that has a blown motor. The motor is a little pricey and before I buy one i wanted to know if any of the ford or mpv 3.0 motors/blocks will work.
Old 06-06-2012 | 06:55 AM
Mazmart Trini's Avatar
Ford Fusion 06-07 3.0l
You will need to change some stuff like int manifold, front cover, valve covers & some other stuff.
-Sheldon.
Old 06-06-2012 | 08:31 PM
DWilson23's Avatar
thanks alot i really needed that info. I figured would have to convert some stuff just wanted to make sure the block and heads would work
Old 06-07-2012 | 07:42 AM
No problem
Old 06-07-2012 | 08:41 AM
Arrow
With a blown engine, chances are your catalytic converters require changing. Some blown engines are due to catalytic failure and the pieces from it go back in to your engine via the EGR system (causing your engine failure).
Also check your rad, coolant and change thermostat. replace all steel coolant lines.
GREAT READING:
All Catalytic Converters - How do I know if my catalytic converter is defective?
How to check your vehicle's catalytic converter. - YouTube
Underhood Service 3.0 ltr issues
Rebuilding the Ford 3.0L: Engine Builder
trev0006
03-05-2015 06:40 AM
cederrowe
11-09-2011 04:56 PM
utkarshseth
10-17-2011 02:07 PM
amazingxfailure
07-17-2007 12:57 AM
chad85
03-13-2007 09:37 PM
Quick Reply: 05 Mazda6 3.0 blown motor question..
