2005 Mazda 6i Engine Stutter & Hesitation
2005 Mazda 6 Engine Stutter & Hesitation
Mazda fam…
I have 2005 Mazda 6 3.0L and I have hesitation & stuttering issues with the engine. The car has 135k been a good ride with NO issues until now. I have diligently searched the board for owners with similar issues & have found threads and read…but I still need a little help please.
History Issues
>> When driving and I give it slight gas the engine stutters/hesitates. It can happen in 6th gear as well as all gears…but I first noticed it between 4-6th gear early on
>> It now happens in all gears. I can be at a stoplight in 1st gear and pull off it can hesitate & stutter
>> Currently now when I go garage, crank car and while foot on break and put in reverse…the engine stutters & hesitates AT A STAND STILL will in same spot. Almost to the point where you think the car could cut off but you know it is not
>> Seemed to begin when the car was hot but now does not matter if cold or hot same issue anytime
What I have done:
>> May/2012 @ 124,500 changed spark plugs for the first time. Did not need too had no problems…there was no misfire, no issues at all just felt it was a good time to change them. Removed the original plug, MOTORCRAFTS. Replaced with Bosch Platinum Fusion (following a Youtube video). Also replaced the intake gaskets.
>> Went months WITHOUT any off the issues about until around Thx’ing & Xmas
>> Last week 3/2013 changed them again. I assumed maybe I have a spark plug issue and replaced back with the OEM Motorcraft AGSF22WM. I called the Mazda dealer and he said before looking up no Mazda used those plugs told him that is what I took out car…was bought new…he said NGK what Mazda uses. After he looked he did see the Motorcraft number I listed above for my car (maybe I should have called around but we only have one Mazda dealer here). I did have to gap these plugs and I was told a gap space of .044 for the Motorcrafts
>> Regardless, I still have the EXACT same issue with both plugs no change at all!
>> No check engine lights nor any codes stored when I check it for any registered codes
>> Someone told me vacuum leak so I attempted to spray throttle body cleaner spray all around the intake & hoses while car was running to see if it idle changed…no changes but I am no pro at this either
I need help…this is wife car and she is killing me and I do not want to take this to the dealer…especially without not knowing what the issue is. I have read O2 sensors, CP-E (whatever that is…I have no idea what that means), and a few other things search.
Advice please…
History Issues
What I have done:
Advice please…
I have cleaned the MAF before and will do again....the EGR valve is a new one to me...by chance know the location of it as well on v6?
I will search as well but was just asking also
Look at my pics: Mazda Forum - Mazda Enthusiast Forums - UseYourNoggin's Album: Intake Plenum & PCV Valve. 2006 Mazda 6 V6 3.0 ltr.
PCV is near the back, just to right by EGR valve but lower.
a 6i = 4 cyl, a 6s = 6 cyl. Know this when searching for parts.
So that still means a 6i = 4cyl...just asking
I want you to go to this site and input your car. At submodel you will need to choose "i" or "s". Choose i and your engine size won't be there. Go back and choose "s" now you will see!
Auto Parts in Canada! - Canada Auto Parts Online
[QUOTE=parcou;136870]Thx...you are right glad to know now...
You did not list coils but I have read other places these cars have bad coils and can go back...problem I have no way to check and those who had a bad one no CEL came on.[/QUOTE]
Coils are expensive from Mazda Dealer, buy them somewhere else. I see you have 135,000 on it. If no cel, coils may be fine but may be weak. It is a good idea to change them with that mileage.
Would you trust these...
02 07 Ford Mazda 6 New Set of 6 Ignition Coil on Plug Coils Pack 3 0L V6 DG513 | eBay
