2006 mazda 6 2.3l
2006 mazda 6 2.3l
idles a little rough, auto zones code reader said timing advanced but this motor has a timing chain not a belt. also codes for crank sensor and cam sensor came up. does anyone know what this is??
I would not expect that they are as long as the engine had proper oil changes and was not red lined frequently.
When a chain wears it gets longer. The guides and tensioner pick up the slack.
Things that can happen are: tensioner spring could break or the mechanism could be stuck. When revving high the chain could jump a tooth.
Therefore: check the sensors first. Then have a look at the cam timing as well. Use a manual to find how to do that. You need to know the location of the timing marks on the crank shaft and the cam gears.
