5th gear fault
Old 08-19-2009 | 03:43 PM
andona's Avatar
Default 5th gear fault
my 2004 mazda 6 2.0td has started to 'jump' out of fifth gear afier approx 20 - 30 miles..
is there anything that would cause this to happen or is it more likely to be an internal fault
its done 42000miles
fully serviced
its a manual gearbox
any help much appreciated
Old 08-19-2009 | 11:17 PM
oldeng's Avatar
When manual transmissions kick out of a gear, it's almost invariably because it wasn't properly in that gear to start with. Causes are worn/ incorrectly set engine mounts, worn bushings on the shift lever, and incorrect setup of the transmission linkage.
It is very rare for it to be due to something inside the gearbox itself on a car which has been properly looked after.
Old 08-20-2009 | 01:11 AM
On the other hand, I once owned an MG. One day I missed a 3rd gear shift. From that day on it ground into, and popped out of third gear unless held in place.
What I'm getting at is that it could also be a worn or damaged synchronizer.
Old 08-20-2009 | 03:57 PM
FFEMT6's Avatar
I believe the 2006-2007 Civic Si's also were having problems with this same sort of thing. I believe it was mostly third gear on these vehicles however.
Old 08-20-2009 | 04:09 PM
The Mazda 5-sps have single syncroed gears after 2nd. My best guess is that the Hondas do too. It's not all that uncommon.
garwood1
02-11-2008 05:56 AM
rrdo
01-28-2008 08:45 AM
rrdo
01-28-2008 08:45 AM
punkrocknj
05-30-2006 08:52 PM
gantw
02-20-2006 01:31 AM
Quick Reply: 5th gear fault
