6 disc changer problem
Old 10-11-2011 | 08:09 PM
Tashjep's Avatar
Default 6 disc changer problem
I ejected a cd and wanted to load a new one but it wouldnt let me because it still thought i had one in there. WHen I press eject it will try to eject it again. When I press load it doesn't do anything. Then I can't switch discs. I disconnected the battery for about 20 minutes but that didn't help. I then tried to eject another disc, which it would but then the same thing happened. Any ideas on what I should do?
Old 10-11-2011 | 11:13 PM
karlt10's Avatar
Checked factory manual - nothing there.
My suggestion would have been what you've done - the battery.
Sorry couldn't help.
Old 10-12-2011 | 03:44 AM
The 6-disks are known trouble makers. At first I was sorry my 3 only came w/the single, but not any more. I have read too many of these posts.
Either replace the player or have yours fixed. It sounds like an internal problem. Either one of the plastic pieces is not retracting and keeping a micro switch closed, or the switch itself is bad. That's my best guess.
Old 11-06-2011 | 01:39 AM
mattierhr's Avatar
Its really trouble maker. You can check the solution of this issue with factory manual. I can also make it easier for you. I just found some links which will be very helpful for you and i want to share with you now.
http://www.benzworld.org/forums/w210...ml#post3644827
CD Changer Repair : Miko's Weblog
http://www.benzworld.org/forums/audi...ml#post3079204
Hope you will be resolve your CD changer issue.
jacobsenM6
02-18-2010 08:58 AM
lsusurfr98
07-21-2008 09:05 AM
obee04
11-18-2007 06:29 PM
mjlljm99@hotmail.com
09-07-2007 10:08 PM
JJerez
08-19-2006 04:00 AM
Quick Reply: 6 disc changer problem
