Driver's door wind noise
Old 11-30-2007 | 11:03 AM
bt1's Avatar
bt1
Default Driver's door wind noise
I have lurked around this forum looking for 6 info before and I really appreciate those of you who took the time to create this forum and those who take the time to respond to posts.
I have a 2004 6s. when the car was parked on the street someone had carelessly backed out of their driveway and collided with my driver's side door. needless to say, the door and front fender had to be replaced. I have noticed that the wind noise coming from the driver's door is louder now and found that the cause of this is the door not shutting as tight as it should be. to give you an idea of how much is shuts compared to the passenger side, I can fit the tip of my index finger in between the door and the door seal where the same is not possible on the passenger side. I was wondering if anyone could tell me where I could make adjustments in an attempt to make the door shut properly.
Old 11-30-2007 | 01:18 PM
Mazmart Trini's Avatar
Default RE: Driver's door wind noise
I would try at the striker, & if that does not work then try the hinges.
Old 11-30-2007 | 07:12 PM
bt1's Avatar
bt1
what is the striker? also, is there anything in particular I should be looking for with the hinges?
dnme
03-24-2014 09:34 PM
palang81984
07-01-2013 07:44 PM
Traxx
02-04-2012 04:13 AM
rojenk
08-09-2010 04:20 PM
CharlottenEddiesdad
07-22-2007 12:55 PM
Quick Reply: Driver's door wind noise
