Front Brake Upgrade for Mazda 6 2004-2008
Old 11-09-2013 | 04:34 PM
Talking Front Brake Upgrade for Mazda 6 2004-2008
This would be a great upgrade for the front of your 2004-2008 Mazda 6.
You must have 18" wheels for these to fit.
I think the Black Calipers are the way to go. Love the 2 piston caliper for extra clamping.
All hardware included.
Calipers come with Clear Anodizefinish. Optional polishing or powder-coating available.
Includes 13 inch Turbo slotted rotors with Xtra Life plating.
Includes SuperTwin 2-Piston aluminum calipers.
Includes high performance pads.
Here is a link to purchase them. Even though the pics are the same (red calipers) they are the proper ones. No pics available for every model. Part # changes for the color by changing the last digit(s).
Black Calipers: SSBC Performance Brakes SuperTwin 2-Piston Disc Brake Kit - A174-1BK - Marken Performance & Restoration Inc.
Polished Calipers: SSBC Performance Brakes SuperTwin 2-Piston Disc Brake Kit - A174-1P - Marken Performance & Restoration Inc.
Red Calipers: SSBC Performance Brakes SuperTwin 2-Piston Disc Brake Kit - A174-1R - Marken Performance & Restoration Inc.
Aluminum Calipers: SSBC Performance Brakes SuperTwin 2-Piston Disc Brake Kit - A174-1 - Marken Performance & Restoration Inc.
SSBC Performance Brake Systems gives you Bolt on Performance you cant beat! The multi-piston brake kits are designed to replace your O.E. brakes. Designed with maximum clamping force and even pressure distribution across the brake pad, you wont believe the difference in braking! SSBC kits offer the ultimate braking performance in a compact design. Made from billet aluminum, the kits are coated with a clear anodize for maximum corrosion resistance both internally and externally. Most of our easy bolt on systems include grade 8 hardware, necessary installation components, performance brake pads, slotted or cross drilled rotors, braided hoses, power boosters, master cylinders, ect.. The list goes on and on, check with your retailer for exact contents. All aluminum calipers are made in the USA. Kits will fit most popular wheels*. Replacement pads are available off the shelf at your local parts store.
Most kits are available with optional red and black powder coat and polishing.
311boom
04-06-2022 12:37 PM
mjj078
02-25-2014 09:09 AM
EROD
07-31-2009 02:02 PM
titanium11
01-26-2009 04:44 PM
