Front squeak
Old 03-05-2013 | 08:25 PM
Vodhunter's Avatar
Unhappy Front squeak
I am trying to locate a squeak i have been getting on my front right side. I can hear it when ever i hit a bump and i am also hearing it when i am turning. When i am turning i an only really notice it like when i am in a drive-thru. I tried to locate it last night by tearing into that side but i was unable to replicate the noise. It will only make the noise after i have been driving for 5-10 minutes. What could be the possible culprits i should be looking at? A part of my thinks i should replace the part i have in the link below. And FYI the car is a 2007 Mazda Mazda6 2.3L MFI DOHC 4cyl. I did spay the entire area down with WD-40 when i was done and the squeak was less notice able but still there.
Duralast/Sway Bar Repair Kit (1880251) | 2007 Mazda Mazda6 4 Cylinders C 2.3L MFI DOHC | AutoZone.com
Old 03-07-2013 | 01:08 AM
Common problem is the lower arm, the straight 1 not the curly 1.
MAZDA 6 LOWER SUSPENSION TRACK CONTROL ARM
Old 03-07-2013 | 08:24 AM
Vodhunter's Avatar
Thank you grim. I will check it out once my repair manual shows up in the mail.
Old 03-17-2014 | 12:46 PM
toddsmazda6's Avatar
Question 2006 mazda 6 front suspension squeak
HELP my 06 mazda 6 left front suspension squeaks. Sound can be repeated when pushing down on front end always comes from the drivers side. Squeak comes from front suspension components not caliper. Can't dial sound in if it's strut, tie rod end, swing arm bushings ext. Any ideas?
Old 03-18-2014 | 06:45 AM
Most likely the lower arm bushes followed by lower ball joints.
billhendley
01-16-2007 08:11 PM
spdracer7
12-28-2006 04:42 PM
airbauer333
06-26-2006 07:20 PM
jstone_311
06-07-2006 05:33 AM
Lev
05-08-2006 06:07 PM
Quick Reply: Front squeak
