Fuse location...
Fuse location...
Hi. I was wondering if anybody knew where I can get info on fuse location for a 2006 '06 s? I would like to located, in particular, the fuse for the keyless entry. However, it would be nice to know what fuse is for what. Thanks for the help!
RE: Fuse location...
Well there are two fuse boxes on the mazda 6. I belive the one for the stereo and lights and etc is left of the pedals. You just have to pull off alittle plastic tab that says fuse box. Also the other one is under the hood next to the battery. The top should just pop off. I couldnt tell you which fuse is which, check your manul for the wiring diagram.
Since were talking about fuses, I got my V1 plugged into my cigarette lighter. Everytime I hit a bump in the road, or shift, my V1 will turn off and then back on. Could this be the fuse was short circuited when I installed my CAI and now I need to just put a new fuse in?
Some of the fuses supply power to a lot of different systems and not just one so is close to impossible to list what each fuse would go to.
If you have the Advanced keyless entry with the credit card sized remote then the following fuses would supply power to the system module. 15 Amp ROOM, 15 Amp ENGINE, and 5 Amp MIRR.
If you only have the standard keyless system then only the 15 Amp ROOM fuse is involved.
All of these fuses are in the underdash fuse box on outer side of drivers footwell.
box, cigarette, circuit, computer, fuse, fuses, lighter, location, mazda, mazdaspeed, mazdaspeed6, room, shiny6, short, troubleshoot
