Help! Vibrating Issues!
Old 04-13-2007 | 12:53 AM
MrSpike118's Avatar
Default RE: Help! Vibrating Issues!
Hey, I have made sure the tires and everything are all in check! I even just filled up with Nitrogen and it still had the flat spots! What can ya do? Thanks guys!
  #22
Old 04-13-2007 | 01:58 AM
rx4to6's Avatar
Have you tried 35 psi? Is flat-spottinga cold weather issue only? Unlike summer tires, A/S or winter tires should remain soft below 6' C. May be that's the problem.
  #23
Old 04-13-2007 | 11:41 AM
MrSpike118's Avatar
I had them up to 37. It is just the way the tire is made, with the nylon I suppose...oh well!
  #24
Old 04-13-2007 | 02:40 PM
ThE_RusH's Avatar
37? Thats really high. Ive had 5 cars, all diffrent styles and sizes and none of them were ever that high. Who informed you that was the right psi? If its only word of mouth.. i would check online with the tire company and see if they recommend a lower psi. For smaller cars, i believe 28-32 is the norm. If your way over the normal limit of the tire.. youll make a bubble effect on the tire. Combined with the cold ( meaning bubble frozen on tire till warm ).. youll get wobble for sure.
Definetly check for that..
  #25
Old 04-13-2007 | 04:13 PM
sstlaure's Avatar
If they are stock tires on stock wheels the correct inflation pressure is on a tag inside the driver's side door. Other than that, you want to make sure you have a good even pressure map across the contact patch of the tire. A little dust on the ground and a nice clean tire to a good job of showing you where the tire contacts the ground.
I haven't had any flat-spotting/wear issues with my Toyo Proxes FZ4's even with a Prokit drop.
  #26
Old 04-14-2007 | 01:54 AM
MrSpike118's Avatar
haha, no I dont use 37 psi all the time. I just tied it to see if it would get rid of the flat spots. Like I said I have the nitrogen in the tires now. But I appreciate all of your help!
  #27
Old 04-14-2007 | 03:58 AM
rx4to6's Avatar
Nitrogenwon't helpmuch sinceordinary air contains about80% nitrogen.
chisan
12-05-2008 02:14 PM
chisan
02-29-2008 01:32 PM
Y3H3Y
09-17-2007 02:54 PM
Dec
04-08-2007 07:34 PM
Max5
12-20-2006 11:29 PM
