I have a question about my lights
I have an '05 Mazda6 Si 4 cylinder and absolutely love my Maggie (I know it is crazy to name your car but when I have to yell at the car for something stupid then you have a name to scream). I have put almost 40k miles on her since buying her used 2 years ago. I am in the process of putting in HID headlights and have found a company that has the bulbs and ballast for $250 but I need to know if it is possible to be able to keep my low beams on when I turn on my highbeams. Does someone know the two wires that I can reverse in the steering column wire harness that switch the passing light pull to the highbeam push? Thanks!
RE: I have a question about my lights
When it is really dark and nasty out have you ever just held your switch on so that you can seel just a little better? That is all that I am trying to achieve. I don't use my highbeams a lot and with the high intensity lights that I will be putting in I don't imagine that I will use them anymore than I do now but when I do, I want to be like all the other cool cars. You know, BMW, Mercedes... I want to look like an expensive pocket rocket even if I'm just a 4 banger 6 hatchback[sm=happybounce.gif]. With the HID's you will see blue spots, red spots, yellow spots, spots all over the place!! SPOTS, SPOTS, SPOTS
does anyones elses 6 have something on the drivers side headlight that cuts the bulb output short, what i mean is that to me it appears mazda has something infront of the bulb only on the drivers side that makes it so the beam on the drivers side has a shorter output that the passengers side, i was wondering if it was just my car or some kinda saftey issue thing.
marc515
07-13-2023 11:41 PM
