lookin for engine specs
I need to know all the engine specs. bore, stroke, pistons, rods, crank, cam, head cc's, compression ratio, injector size/flow. also if anyone knows what is internaly different with this engine vs. the noble m400's v6. i have a few progams and lookin to do a twin turbo set up in the future.
RE: lookin for engine specs
i don't have all the info, but doing the twin isn't too bad, it's been done. the problem is you, at this point, will have to do a ground up type of management system as the Mazda ECU won't allow for any fun....at all.
if you look into the nobel stuff, i think even on the site, all the info on their blocks are there, as you can order just the block from them if needed. outside of strength of the internals and compression, all else should be pretty damn much the same.
