low beams do not work
Old 01-24-2008 | 03:45 PM
emc1220's Avatar
Default low beams do not work
anyone else having this problem? my high beams work and my fog lights work. but not my low beams. any help is appreciated, like a wiring schemitic or anything.
Mazda 6 2003
thank you
Old 01-25-2008 | 09:45 AM
Mazmart Trini's Avatar
Default RE: low beams do not work
Did you check to see if the bulbs are blown?
Old 01-25-2008 | 04:31 PM
emc1220's Avatar
i dont think they both would have blown at the same time. but i havent checked yet.. its a mess trying to get to them
Old 01-25-2008 | 09:38 PM
rx4to6's Avatar
Check the fuse before you starting fooling around the bulbs. They are a pain to take out and re-install. Good Luck.
Old 01-26-2008 | 07:51 PM
And... check the low beam relay to see if it's working correctly too 'Course if like rx4to6 says, the fuse is blown the relay will not work either.
Old 02-02-2008 | 01:37 PM
orangefur's Avatar
You probably already figured out your problem by now, but I bet it is the bulbs. Mine did the same thing. I got my car inspected so I know they were both working, then a week later they were both out. I took it to the dealer thinking that there was some big electrical problem that would be covered under warranty and it cost me $200 for them to change the bulbs. Like someone said above it is a PITA to do it.
Old 02-13-2008 | 09:45 PM
Capser6's Avatar
I'm having the same problem...how did you fix yours?
Old 02-18-2008 | 02:13 PM
johnblaze1269's Avatar
I have an '03 6 an have had a sinmilar problem. One of the low beams will go out every 3-4 months or so. I'll replace it just to have the same happen again in a few months. I think the 6 does have some definate electrical problems.
Old 02-19-2008 | 09:36 PM
Capser6's Avatar
I took mine to the dealership nd they traced the problem back to a bad fuse. I'll see if that was truly the problem 3 months from now.
kenp005
04-25-2022 01:11 AM
trs
06-27-2007 04:31 PM
dgk996
03-19-2007 08:52 PM
dulcetcalamity
01-19-2007 12:50 PM
mazdamx3
07-30-2005 12:05 AM
