Mazda 6 problem DPF and power after removed DPF filter
DPF filter was cutted off and set a new patch. After that drive 350km. DPF warning light start flashed and turns on check engine light and lost power.
In service they repached again. Then I drive 750km and it happens again. DPF light flash, turned on check engine light and lost power. I scan for errors and it showing error P2463. Please help. What'sa problem can be? Why it start again ?
Mazda 6 2008 2.0 diesel.
Initially the DPF light came on without flashing. I tried driving at high speed for a time as well as adding DPF cleaning fluid to the fuel and taking it for a drive. Eventually the DPF light started flashing and in turn the engine light came on and I Tutuapp 9Apps Showbox believe the car has gone into “limp” mode.
