mazda6 door panels
RE: mazda6 door panels
Here is info from workshop manual for front door. ignore battery cable part.
FRONT DOOR TRIM
FRONT DOOR TRIM REMOVAL/INSTALLATION
Disconnect the negative battery cable.
Open the cap using a small screwdriver, then remove the screw.
Remove the inner handle cover.
Remove the inner garnish.
Remove the cover, then remove screw A.
Remove the lens cover, then remove screw B.
Disengage clips A from the front door using a fastener remover.
Pull the front door trim upward, then disengage tabs B from the front door.
Disconnect the power door mirror switch connector and the power window main switch connector (driver's side) or power window subswitch connector (passenger's side).
Remove the courtesy light.
Remove the front door trim.
Remove the switch panel from the front door trim.
Install in the reverse order of removal.
[IMG]local://upfiles/1377/19DBC4310E674AA8A26790686979D609.gif[/IMG]
[IMG]local://upfiles/1377/1869FCA1D24049E08A306BE929CAE36B.gif[/IMG]
FRONT DOOR TRIM
Here is for rear door panel.
REAR DOOR TRIM REMOVAL/INSTALLATION
Disengage clips A from the rear door using a fastener remover.
Pull the rear door trim upward, then disengage tabs B from the rear door.
Disconnect the power window subswitch connector.
Remove the rear door trim.
Remove the switch panel from the rear door trim.
[IMG]local://upfiles/1377/CE85D7B3157148BFA534415685B8EE4B.gif[/IMG]
[IMG]local://upfiles/1377/83ED082F8735489182B1F657BE0819DF.gif[/IMG]
mtrain
12-10-2007 10:31 PM
