Mazdaspeed 6 Clutch Pedal Vibration/Noise Help!!!!!ASAP!!!
Old 04-07-2009 | 06:58 PM
2k6speed6's Avatar
Default Mazdaspeed 6 Clutch Pedal Vibration/Noise Help!!!!!ASAP!!!
I Just recently got this issue. The clutch pedal vibrates engaging the pedal in about 1" or so. Vibrates bad, like bounces on your foot when rested on it, foot massage. As you continue to push it in more it goes away. Also when the pedal is vibrating there is a noticable noise in the cabin of the car and more in the engine bay. Sounds like a knocking noise and goes away when clutch engaged. I have seen many searches on this topic. But i havent seen a solution at all! I have already replaced the flywheel with a light weight flywheel thinking that was it and still have the same problem. The car is apart right now for the second time. The whole clutch assembly seems to be perfectly fine looking at it on the lift. I ordered a clutch and pressure plate today but not even sure thats going to fix it. I need a soultion or help asap!!!
Old 04-07-2009 | 07:50 PM
It sounds like a bad TOB to me.
OziSpeed6
08-04-2013 11:27 AM
wykyd
09-24-2010 08:11 PM
mariat
01-24-2009 05:55 PM
DouglasH
11-23-2006 02:08 PM
ackerman73
09-14-2005 10:42 PM
Quick Reply: Mazdaspeed 6 Clutch Pedal Vibration/Noise Help!!!!!ASAP!!!
