Pos Battery cable
Old 01-10-2013 | 04:20 PM
eleebid's Avatar
Smile Pos Battery cable
Hi all,
My positive battery cable connector has corroded off on my Mazda 6S.
I cut the cable back and used an after market connector but it is starting to corrode
as well.
Where can I get a factory replacement?????
I have searched the internet; no luck.
Any body else have this problem???
E
Old 01-10-2013 | 04:45 PM
Haven't had the problem on the positive cable, just the grounds.
Have you checked your grounds?
I recommend an extra ground to these areas: body, engine block, throttle body, tranny if automatic.
Another bad ground is in front of the driver side wheel under the air box. I re-routed it up top.
Old 01-10-2013 | 05:21 PM
Kevinkpk's Avatar
I'd clean it, and put some bearing grease on the terminal.
GopherInWI
10-14-2024 05:28 AM
redking
02-26-2015 12:53 AM
Gateway Lady
11-26-2012 12:18 PM
kbaby77
11-02-2008 05:20 PM
nathant
02-03-2007 10:17 PM
