Power problems
Old 06-05-2013 | 10:10 AM
tanprotege's Avatar
Gerlyne, I am not into calling people retarded. Usually that kind of stuff fires back!
After resetting the ECU it needs to relearn a few things over time. It will acquire some data about your driving style and adjust timing and fuel trim. If you have an automatic transmission it will adjust shift points.
I do not know if the locks are being affected by resetting the ECU. It is possible that this is coincidental. If you have a second fob use it to see if it makes a difference. Also fobs have a battery in them. Replacing the battery may cure the problem.
There are some computer wizards on this forum I hope they chyme in.
Old 06-05-2013 | 11:59 AM
Gerlyne's Avatar
I don't have a second fob and I have replaced the battery but I did notice that it was working before I did the reset and then after I get nothing. The car still locks it just doesn't arm the alarm system
Old 06-05-2013 | 05:35 PM
tanprotege's Avatar
I am afraid, I am not knowledgeable in regards to alarm systems.
crazy202
11-15-2011 01:30 AM
imurphy
09-04-2010 01:02 PM
x0054
03-08-2008 10:37 AM
Davonz
07-02-2007 12:07 PM
929woes
12
09-13-2005 11:24 PM
