Question about Oil Consumption/ Loss
Hello,
I have a Mazda6 2004 (V6, 3.0L enginge) with 145000KMs (90000 miles) and it has been loosing oil...and I can't figure out why or how (neither can the Mazda Dealership)
In between the recommended oil changes (every 8000 kms) I am continutally having to add 2 to 3 L to keep the oil at a safe level.
I don't see oil dripping from my car or smoke coming out of my exhaust when driving on the highway
What I have done to try and solve this problem (within the last year or so)
- changed Crank Seal
- changed oil pan and drain plug
- changed PCV valve.
I am still left with the same oil loss...and the Mazda Technicians are at a loss also.
I was curious if anyone else had the same problem with there Mazda6...
Any advice/comments would be greatly appreciated.
The PCV valve was not changed before I did it in 2009
I haven't done the compression check yet...but it was something that I was going to bring it up with the dealer. I wasn't sure if this would help diagnose the problem
I will check the coolant to see if there is any oil in it...thanks
Probably carbon buildup on the scraper rings and oil rings. It is most likely burning the oil at rpm so not noticeable. A good decarbon of the engine using techron and/or seafoam with marvins marvelous mystery oil in the crankcase could help if so.
