Radiator Leak?
Radiator Leak?
I went in today to get some diagnostic on a CEL (see other thread). They said I needed a new radiator as there was a leak.
It was pretty expensive, $800 job or so. $400-ish for the part and $350 for the install. Not getting any coolant leak or smell.
Should I get a second opinion? Monitor fluid levels? Just go ahead and replace it? I have other things on a higher priority on things to fix right now....but thoughts?
I believe I've done a coolant flush at once of my scheduled maintenances. I'm not sure. I'll keep an eye, I had a radiator leak on my last car (VW) and it caused all kinds of hell for me, so I kind of know what to look for.
Did they spill stuff at the top of the rad, the hose connections was not cleaned properly and didn't seal, causing you to go back. That corrosion is due from a leak or a spill (spill not cleaned afterwards). When I did my flush & fill I went to a rad specialist shop (changed thermostat and have had 0 issues since doing it).
north maineic
07-03-2007 04:05 AM
jonnyfifes
05-15-2007 02:20 AM
Dino1956
03-18-2007 08:41 PM
mazda_roller
03-12-2007 11:25 PM
