Rear shocks, mazda 6 07
Old 04-30-2012 | 08:34 AM
PHILKANE's Avatar
Unhappy Rear shocks, mazda 6 07
I had my shocks changed and now you can hear every bump. I put sound deading stuff in the trunk and not much difference. Any one else have this problem?
Old 04-30-2012 | 08:37 AM
Mazmart Trini's Avatar
What kind of shocks did you install?
Old 04-30-2012 | 09:03 AM
Try increasing and decreasing tire pressure by 2-3 psi. Front tires should be within 2 psi from rear as well. You'll have to experiment. The tire pressure is listed on the driver's door post for the stock OE tires. Other tires may run better slightly above it.
16" wheels will be smoother than 18" wheels. What brand and size is your tire?
More: Tire Pressure - Keep it in check
http://www.tirerack.com/tires/tirete...e.jsp?techid=1
Old 04-30-2012 | 03:55 PM
He said he changed his shocks, not tires.
Old 04-30-2012 | 07:41 PM
The shop may have adjusted his tire pressure without telling him as a courtesy.
Tire pressure is also important for ride quality. They are both part of the suspension and affect ride quality.
New shocks may also be stiffer than worn out ones, which he may also be feeling.
Old 04-30-2012 | 08:58 PM
PHILKANE's Avatar
I have gabriel shocks and goodyear tires.
PearlWhite5
08-31-2013 08:51 AM
BCNorth
04-27-2012 09:13 AM
NickC
10-15-2011 12:04 PM
Aubrey
12-06-2010 09:09 PM
Quick Reply: Rear shocks, mazda 6 07
