speed
Old 05-14-2007, 05:08 PM
bree's Avatar
Default RE: speed
Hi,
MrTea, how did you bypass the gov. ???
Old 05-14-2007, 08:11 PM
Default RE: speed
well, nothing is stock. from having a build ford focus engine, HiBoost turbo and now swapping out the atx for a ford focus mtx....the biggest thing is the ecu though. i run a haltech standalone unit.
Old 05-14-2007, 10:49 PM
wsoape281's Avatar
Default RE: speed
you can add a stand alone that will get rid of some of the stock settings. it just piggy backs onto the stock computer.
Old 05-15-2007, 05:12 PM
bree's Avatar
Default RE: speed
Is that piggy back better than the unichip piggy back??
Old 05-15-2007, 05:33 PM
wsoape281's Avatar
Default RE: speed
unichip is designed more for turbo and i think is the best thing that you can do to a turbocharged car. for naturally aspirated cars, i think that you need to find another way to go. stand alone is a term for the engine management style.
Old 05-15-2007, 08:00 PM
Default RE: speed
didn't quite follow what the last post meant.
a piggyback tweaks the inputs of sensors to get desired results from the stock ecu. a standalone makes it's own decisions, you just tell it what you want.
right now, Unichip isn't out for the 4cyl that i know of. Haltech doesn't work on the V6 as of yet. so there are no decisions to make. you CAN get a full standalone with fuel and timing for the 4cyol by way of Microtech, but it's in teh $1400 range. for the Unichip to work on a boosted setup, you would need a purchase a few other leads/sensors as well.
Old 05-16-2007, 09:17 AM
bree's Avatar
Default RE: speed
MrTea I was looking to order a unichip but they offer two kinds.
This might sound stupid but I want to get the wright one. One is for stock and the onhter is for a "CAI" what dose CAI stand for??
Old 05-16-2007, 12:57 PM
Default RE: speed
CAI stands for Cold Air Intake, if you already have a CAI on your car or plan on installing one soon.
Old 05-16-2007, 03:14 PM
Jokerschild584's Avatar
Default RE: speed
i agree with MrTea ... i had have mine to about a buck and a half (approx 143) ... with no problem , all with stock aplications, .. i would suggest you simply just give your car a staight tume up , certian things can cause lag in a car, old, clunk oil... clogged/clogging oild filter , old antifreeze liquid, (the cooler the engine is , the better it runs) spark plugs, and possible the coil pack.. properly inflated tires (big drag) ... heres a funny one to remember , you know how a parashute stops a person (if you didnt) i would suggest closing all windows when going at high speeds, wind is a big air push/drag ... also make sure the wind is in your favor ... not againts your car, (dont do it on a windy day) if not , your just a big air damn ... lol... anyways, the only things i've ever changed in my car thats not 'stock' is that i've installed a Clutch Masters clutch Stage 1 ... because i've experienced slippage at high speeds, with minimal torq application...
hey chief, i'm under the impression that you may have an automatic car, ... you do realize that a manual trani surpasses an automatic, ..
good luck with your speeding chief!
Old 05-17-2007, 11:42 AM
Default RE: speed
where you from Joker, never seen a stock US mazda able to crack the 120, unless your a speed. and i personally wouldn't suggest going over that if the car is stock anyhow.
Bree, i think you got your answer about the Unichip. but keep in mind, as Stealth said, you need to go to a Unichip dealer to get the gov removed.
lostbethus
06-12-2022 09:30 PM
Alucard
02-11-2006 10:19 PM
epheterson
08-01-2005 02:44 AM
JavaAddict
07-22-2005 11:33 AM
guyonearth
07-15-2005 03:34 PM
Quick Reply: speed
