Squeaking Brake Pedal?
Old 01-17-2007 | 12:03 PM
davidteachey's Avatar
Default RE: Squeaking Brake Pedal?
Absolutely fabulous, babyhuey....thanks!
David
Old 04-06-2007 | 03:09 AM
H15A5H1's Avatar
i recently got the same problem. i bought the 2007 mazda6 5-door 2weeks ago. first it was creaking noise coming from the front passenger door, now squeaking brake pedal. will the dealer be able to fix it if i take it in? it should be covered on the warranty. (im bringing the pdf file posted by babyhuey)
Old 04-16-2007 | 02:06 PM
selman's Avatar
Exact same thing happened to me with my 2003 6s. They replaced master cylinder and the booster at the dealer and the problem was gone. They replaced both the master cylinder and the brake booster, I don't know if both were the cause of the squeak together or just one of them was the cause and they replaced the other for some other reason. But at the end, problem never occured again.
Old 06-05-2007 | 11:24 AM
To concur with wagonboy,
I was at the dealership today for unrelated service, and the Service Advisor said that in his experience, a power flush/bleed/replacement of the brake fluid has been the solution. He admitted that he doesn't know WHY that works, just that it does! I'm gonna give it a try, if for no other reason than because it's smart routine maintenance. I'll report back if it stops my brake pedal squeak or not. Cheers,
David
Old 06-13-2007 | 12:09 PM
FlaBlueSkys's Avatar
Seems to be a very popular topic, over 1000 have viewed the post. I also have the brake pedal squeak, started ~ 20,000 miles, service advisor was clueless, said that my brakes were better that the car he drives! Had the service tech check it out - couldn't find any problem either! Nice to know that something can be done.
Old 09-12-2007 | 08:44 AM
I'm going to have the brake fluid power-flushed/bled on Monday 9/17...in the days following, I'll report back if my squeaky brake pedal has gone away or not. Lets hope so!
David
Old 09-25-2007 | 09:35 AM
Having driven the car for over a week now, it seems that the brake fluid flush/refill/bleed has cured my squeaky brake pedal. Woo hoo!
David
Old 09-25-2007 | 05:30 PM
hixx's Avatar
Master cylinders have to be vented so they accumulate moisture through humidity,plus the rubber seals wear and debris from them build up. Eventually the seals do not get completely lubricated because the debris is blocking the fluid from getting to the seal. It still seals but the main cup seal gets dry and squeeks. Rubber on metal.
Old 09-26-2007 | 04:40 PM
Good explanation hixx.....I buy it!
David
neverfollow
11-06-2007 06:41 PM
Burkhart
04-20-2007 05:56 PM
ewilderm
01-24-2007 12:07 AM
1owner
01-11-2007 01:12 PM
mitch
07-22-2006 12:00 AM
