Tire width Mazda6
Old 08-24-2010 | 07:02 PM
BoCoffman's Avatar
Default Tire width Mazda6
Love my Mazda6 sTouring Plus (2010) Still have the standard 17" wheels and P215 width that came with it. Would like to go a little wider when it's time for new tires - just like the look. Will the standard wheel go from 215 to 225 width? I'd probably keep the aspect the same, maybe go down 5mm. Just don't want to buy new rims but go wider on the tires. Thanks.
Old 08-24-2010 | 08:47 PM
shipo's Avatar
The factory 215/55 R17 tires that came on your car have a diameter of ~26.3", if you opt for 225/55 R17 tires on your factory rims the diameter of your new tires will be ~26.8", which will be enough to make a noticable difference in your Speedometer and your Odometer (they'll both indicate low, or said another way, you'll be moving faster than indicated). That said, if you move to 235/50 R17 tires (which should fit on your rims and still clear the inner fenders at full steering wheel lock), then your speedometer and odometer will be spot on.
Old 08-25-2010 | 12:26 PM
CKeffer's Avatar
+1 I'd recommend 235/50 as well. You'll get even meatier tires than the 225's and as Shipo stated, still clear the fenders.
Old 08-25-2010 | 08:39 PM
BoCoffman's Avatar
Great advice. Thanks.
Just curious...I can see diameter changing speedometer/odometer accuracy, but how does width do that - is it the added drag? If that's true, will I actually lose true torque output?
Old 08-25-2010 | 08:41 PM
BoCoffman's Avatar
...sorry, read the replies again. I see diameter does go up. I get it. Thanks
joger01odzr
02-14-2014 03:02 AM
SZiggy
01-15-2013 11:23 AM
mommymazda5
01-20-2010 09:54 AM
jao0025
04-11-2008 09:06 PM
Krameryah
01-19-2008 10:00 PM
Quick Reply: Tire width Mazda6
