Tons of dashboard lights/needles idle/lurching problem
Hi, I have a 2007 Mazda6 that has an ongoing problem. When it's symptomatic, the following happens when I start my car:
Thanks a lot!
- Sometimes, when I start it up, the following lights come on:
- Battery
- Brake
- AT
- ABS
- Check engine (is always on so not sure if it's special)
- When I shift it out of park and into reverse, it lurches
- Then it can drive, but:
- The speedometer and RPM needles stay at zero
- Sometimes it feels a little lurchy
- Sometimes the brake feels a little ABS-y
- Then it fixes itself
- The needles "flicker" (go up and down again several times)
- The bad lights go off but the skid light comes on
- Then the skid lights go off and the needles are normal
- August only:
- After it had been fine for three months, the problem happened again when I hit a bump
- Previously it had only been on startup but this time it happened mid-ride
- I think once it also started bad but fixed itself on a bump
Thanks a lot!
