tough starting, won't restart when hot
Old 07-07-2021 | 04:09 PM
Epe's Avatar
Epe
Default tough starting, won't restart when hot
Own a 2007 mazda 6 w/ 185k. Ran perfect until this. Tough starting like it's fouled, stumbles and then catches. accelerates slowly. Too much gas it bogs, too little it stalls. Runs normal a while but as it gets hot wants to die at low revs. Finally if you turn off when hot it'll restart immediately but if you wait it won't, then it has to cool back down to start same process. Replace/cleaned lots of things with no luck. Talkative guy at mazda dealer swears its carbon buildup in the intake manifold. Says it'll start because carbon hasn't absorbed fuel yet. Says when it does starts and you run it a while carbon absorbs gas and when you shut it off it shows too much fuel?
Does that sound possible? Anyone else have this?
Old 08-11-2021 | 07:06 PM
winkybil's Avatar
2001 RAV4 2.0 cranks good when engine is cold, but when I turn it off to run in the store right quick it doesn't start. I crank and crank and it Tutuapp 9Apps Showbox doesn't start. I would have to wait until it cools down a bit to start the car.
Dragon_CT_203
05-30-2020 03:03 PM
dlive3645
06-11-2012 06:05 AM
heryrg
10-14-2009 07:59 PM
averageguy
10-23-2006 09:06 PM
juju
05-06-2006 09:59 PM
