Understeer and Oversteer...
RE: Understeer and Oversteer...
A front wheel drive car will almost always understeer, which is good because it's easier to deal with especially in bad weather. You can minimize understeer by using performance tires with more grip than the stock tires.
racing beat makes a suspension kit that is supposed to give the 6 more neutral handeling, but idk how well it actually works. Also when you release the gas in a turn, if timed correctly, it can make the back end "step out", but it's a more advanced technique, something akin to trail braking.
-Cameron Keffer
-Cameron Keffer
r197
05-05-2010 01:30 AM
94 protege's Drilled and slotted rotors, struts and springs, crank pulley and steel braided brake li
dr4g0n3
08-11-2007 08:16 PM
