Valve Noise
Old 04-30-2007 | 06:01 AM
zippy's Avatar
Default Valve Noise
My 2006 V6 Sportwagon has made valve/tappet noise almost since new. It always happens when the engine is hot and idling or just above an idle. Around 1000 rpm it is loudest. I saw some older posts on another forum that said this was common with the Duratec V6 and nothing to worry about. Anyone else have this? The car has 24k miles now and if it's a problem I'd like to get it fixed while I have the warranty.
Old 04-30-2007 | 07:36 AM
liquorbeans's Avatar
Default RE: Valve Noise
I have an '05 sportswagon that does that same thing.
Old 04-30-2007 | 01:01 PM
dentinger's Avatar
you have been keeping up with the oil changes right??
and are you sure its just not the fuel injectors ticking??
cuz ive heard some pretty loud ones...
Old 04-30-2007 | 01:18 PM
sstlaure's Avatar
My wife's 04 Sportwagon has the same thing....53,000 miles and counting. All of the 3.0L I've heard sound similar.
If you're worried that yours is louder than normal, go to a dealer take a car for a test driveto listen for comparison. (The test drive will heat up the motor.)
Old 04-30-2007 | 06:58 PM
davidteachey's Avatar
I had an Isuzu Trooper, with a GM-sourced V6, and some reasonable valve noise was expected...it was part of the not-so-great valvetrain design. A band-aid was to make sure that the engine oil was always fully topped off. So, regarding your 6, I'm gonna say "keep that oil topped off, and hope for the best".
David
scubajohn
05-19-2019 09:09 AM
djsmbs@prodigy.net
08-27-2011 01:08 PM
mickpdx
01-14-2009 11:38 PM
joshy28
07-14-2007 01:36 PM
Quick Reply: Valve Noise
