Video: 2004 Mazda6 (i4), need help diagnosing pulley noise.
Old 03-25-2016 | 02:53 PM
biggerontheinside's Avatar
Default Video: 2004 Mazda6 (i4), need help diagnosing pulley noise.
Just as the title states, I am getting multiple and strange sounds coming from the pulleys. It almost sounds like a combination of a bad idler and a bad automatic drive belt tensioner. However and also, about 3 years ago, the previous engine spun a rod bearing and it was replaced by the current engine (an online bought rebuilt engine). There didn't appear to be any issues after installation, but now, it appears, that there is a slight wobble in the crankshaft pulley and maybe that is accounting for some of the knock-like rattle noises? I am honestly lost on this one, and any help or opinions would be appreciated before I start playing the process of elimination merry-go-round. Thank you.
Old 03-26-2016 | 07:59 AM
You need to buy a cheap Stethoscope & listen to each pulley.
Old 03-26-2016 | 04:42 PM
Just bought a cheap stethoscope off harbor freight, should be here in a couple of days. Thank you.
Old 03-26-2016 | 04:46 PM
Sparky202's Avatar
In the mean time, squirt a shot of WD-40 on the belt, flat and ribbed sides. If the bird chirp changes or goes away, replace the belt. I've heard alternators rattle like that but it's rare, usually tensioner. Grim's right though, cheap stethoscope will take all the guess work out of it.
Old 04-01-2016 | 02:25 PM
Update: Got the stethoscope, and some bad news. It was the harmonic balancer. Looked high and low for a Dayco PB1386N to no avail, apparently the harmonic balancer for this car has been discontinued. Ended up overnighting junk yard grab. Will update once it's in. Hopefully, it is not the belt as well, as it is only ~4 months old or so.
Old 04-01-2016 | 06:35 PM
Sparky202's Avatar
The balancer you say? huh, Not a common thing for sure.
Old 04-02-2016 | 08:39 AM
Update: Replaced harmonic balancer -> tensioner idler started squeal -> replaced auto drive belt tensioner and idler pulley -> alternator pulley started squealing -> replaced alternator -> silence.
bollemus
Suspension
11-07-2012 02:08 PM
Onefreerolla
10-31-2012 04:44 PM
kannank
01-16-2012 09:52 AM
jafo104
01-10-2008 07:38 AM
kidr
07-30-2007 02:01 PM
Quick Reply: Video: 2004 Mazda6 (i4), need help diagnosing pulley noise.
