Engine Control Module
Any electronic troubleshooters know the answer to this problem?
1986 626 2.0L FI. I don't have any voltage to the TPS, Air flow sensor, and the atmosphere sensor. Fuel pressure is 49 PSI and has good spark at the spark plugs. The main relays and open circuit relay are apparently OK. All the fuses are OK.
The engine will start on ether, but without ether is will not start..
Are all of the above sensors and injectors controlled by the engine control module?
Thanks.
Thanks.
Drake
09-13-2006 05:13 PM
