Nut size of Ignition Coil Bolt
Old 04-02-2021 | 06:24 PM
dragan322's Avatar
Default Nut size of Ignition Coil Bolt
Wondered if anyone might know the wrench/socket size for the nuts on the Ignition Coil Bolts on a 2011 Mazda 6. I thought it was 8mm, but it's too large, and 7mm is too small. Trying to change my spark plugs and can't remove those four bolts. Thanks!
Old 04-03-2021 | 01:58 PM
Xvenom82's Avatar
Technically its suppose to be a 8mm. Looks to be rounded off. I would try a 5/16 socket and see what that does
Old 04-03-2021 | 05:05 PM
dragan322's Avatar
Thanks for the suggestions. I looked very closely at all four nuts and they seemed fine as far as I could tell. I did try the 5/16 wrench and that didn't work. Maybe I need to use a deep socket 8". I was just using a regular box wrench. Thanks again.
dragan322
04-02-2021 06:22 PM
pietro1965
09-30-2020 09:52 AM
jeffreylay581
10-27-2018 02:18 PM
Doug Lundy
10-10-2017 03:17 PM
04tribute2.0
03-30-2015 07:59 PM
Quick Reply: Nut size of Ignition Coil Bolt
