Can I make my 06 MX5 Forced Induction?!?
RE: Can I make my 06 MX5 Forced Induction?!?
there is a company overseas that has one, i'm supposed to look em up for someone else as well. it looks like a pretty trick setup, found it in a magazine initially. i'll see if i can find the info again.
HiBoost will do a turbo if there is a market as well, but that's a turbo
http://www.mazda3forums.com/index.ph...8439#msg848439
check out that thread, couple companies in there. though i haven't found anything in a ready for sale position yet.
http://www.stageonetuning.com/index....WPROD&ProdID=2
google is pretty easy to use man!
and if you read that other thread, you'll see you can email Power Enterprise to see what their deal is.
you could always just throw together your own turbo kit and get a unichip to manage it. the only downside i would see to that is if you want to run anything over about 7-8 psi, you would want to do internal modification and new gaskets. i recommend turbo over supercharging just because of the addiction that you will get to the boost and lag.
