Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
turbo & carbs
Old 03-11-2006 | 12:28 AM
mph's Avatar
mph
Default turbo & carbs
need somone with know how to turbo a carbie 13 B
Old 04-27-2007 | 04:03 AM
wsoape281's Avatar
Default RE: turbo & carbs
that gets a little complicated. there are these things called blow through boxes. i have seen them used on big chevys with throttle bodies. not sure how well they would work on carbs though. they are almost always custom built and they are just boxes that mount on the carbs. you will also need a pressure sensitive fuel regulator and the parts of the build that aren't custom will probably involve extensive mods to existing parts.
Old 07-30-2007 | 09:44 PM
82mazda's Avatar
i have a rx7 12a.
i wouldlike to know how to turbo it.
Old 03-24-2008 | 12:05 PM
streetmx5's Avatar
we turboed my buddies 350 with a 100mm turbo out of a cat, you do need to make a blow through carb, then you run an oil line and return and make the manifold for the turbo with the header, you mount the tubo and hook it up to the vaccum lines and put the blow off valve on the carb, then you put the wastegate in the manifold. there is way more to it but you have the general idea.
go to www.youtube.com
type in :100mm trans am, and click on his name and you can look at all his videos.
wayne84
07-27-2022 09:48 AM
bluemazdaprtege
07-02-2010 05:01 PM
madaz666
05-19-2009 10:59 PM
imurfavbuddy
02-20-2008 08:51 PM
nross001
Intake, Headers and Exhaust
07-09-2005 11:40 PM
Quick Reply: turbo & carbs
