random thread to talk about whatever
Old 07-22-2008 | 12:34 PM
Lupae3s's Avatar
Default RE: Random Chat Thread
it allows one to throw the rear end out and not have to deal with understeer.
  #1342
Old 07-22-2008 | 02:35 PM
BiNGO!! It also gives a better feel in the steering and front end/tires in general. Add a heavier rear sway bar and ya' got it!! What pressures (and tires) are you running Jeff? On the street and AutoX?
  #1343
Old 07-22-2008 | 09:29 PM
UrbanmanUSA's Avatar
ORIGINAL: virgin1
35!!!Wuss.Mine are @ 38F/34R COLD!!
ORIGINAL: VB
Hmm, really? I'm not sure what the PSI limit would be for these tires. What would the altered pressures do for me, actually?
My tires show 44 PSI as the max. I ask the same Q as VB ... what is the ben of more PSI in front versus rear? Overall, more PSI = less rolling resistance. But beyond a certain point, handling/grip is sacrificed. Real question is: What is the optimum PSI?
  #1344
Old 07-22-2008 | 11:09 PM
VB's Avatar
VB
ORIGINAL: UrbanmanUSA
ORIGINAL: virgin1
ORIGINAL: VB
I would guess that the PSI sweet spot varies amongst tires.
  #1345
Old 07-23-2008 | 12:41 AM
Lupae3s's Avatar
ORIGINAL: virgin1
on the street i do 37 in front and 36 in rear. at autox usually 41 in front and 37/38 in rear...plus or minus a psi or two for each depending on weather and track conditions
  #1346
Old 07-23-2008 | 06:50 PM
GRRRRRRR!!!!! I'm SICK of this SH*TTT!!
  #1347
Old 07-23-2008 | 07:13 PM
sstlaure's Avatar
ORIGINAL: virgin1
Bad day there Richard?
  #1348
Old 07-23-2008 | 08:17 PM
TWO MONTHS.... CAN'T POST!!!!!
  #1349
Old 07-23-2008 | 08:20 PM
Vince, you are correct. The idea is to stiffen the fronts and leave to rears to flex in the sidewall. Better control, better feel.
  #1350
Old 07-24-2008 | 09:01 AM
sstlaure's Avatar
Typically the weight distribution is more biased towards the front as well. (engine) More weight on the front tires means you need more air pressure in them to accommodate the added weight being applied. This ensures the tiresflex/performconsistently front/rear.
I would think a vehicle with perfect 50/50 weight distribution would want even tire pressure all around.
