wtd mags
RE: wtd mags
there are some on ebay. You should probably find out what your stud pattern is before you look to hard into it.
Because your an aussie i'll help you out...
Most 808's came out with 4x110 PCD (pitch circle diameter), don't take this for granted you should check yous out because you may not have standard hubs.
Other mazdas that had the same origional PCD are:R100, 1200, 1300, RX-2, Capella, RX-3, 808, RX-4, older 929s, RWD 323s, RWD 626s and Series 1/2 RX-7.
I don't really look at other manufacturers that much but i know Simmons, Globes, Challengers and ROH all make for this PCD.
Good Luck, personally i think you should try squeezing on a set of 17's.
