85 GSL-SE Wheel Size Max?
Old 02-08-2010 | 10:17 PM
Teej66's Avatar
Default 85 GSL-SE Wheel Size Max?
I have a 1985 RX7 - GSL-SE. Current tires 205-60-14.
Trying to find inexpensive tires for these rims is impossible.
What is the largest size wheel that can be fitted on the 85 GLS-SE?
Teej
Old 02-26-2010 | 12:29 PM
djs2571's Avatar
looking for inexpensive, just use the stock size... 14" wheels are cheaper than a larger diameter, and wider would probably be more costly too. Not to mention that wider tires don't wear correctly on a narrow rim, I ran into that with 225's on my first GSL-SE.
My second GSL-SE I used a summer set of rims with 205 50R15's - resulting in the same tire OD so no speedo issues. That may be more available, but then you need rims too.
8ball_78
01-07-2009 03:32 PM
EL CANITO ROTARY
03-25-2008 09:55 PM
rx7noobi
03-25-2007 11:52 PM
schmidt8202
11-02-2006 03:48 PM
jim01
05-01-2004 12:09 AM
